2000 40c Fuel/Water Separator
BAS
I have a 2000 40c and Im having an issue with water in the fuel. I changed the filters and it is acting like classic water issues. I do not have a fuel/water separator. I remember reading that you must not slap any FWS on a small outboard but I cant seem to find a FWS specifically for small motoers. Any recommendations to buy would be appreciated. FYI I run high test No Ethanol only and the motor does not have a mixing system, I carefully mix with a measured fuel mix. Thanksgivings
If you are running a portable fuel tank has it been dumped,cleaned and flushed? Was there water in the filters? Has the carb bowl been drained and inspected for water?
