moondrifter
I have lost about 6 oz. of power steering oil in 2-3 months. Checked the bilge, found no oil. Any ideas as to where it's going? Is there any past issues with this type problem. Thanks Moondrifter.
Ayuh,... It's quite possible the P/S Cooler wasn't winterized, froze, 'n split, internally,....
In which case, yer pumpin' the oil, Over-board with the motor's exhaust water,...
How do you test em? Or is there a place that tests em?861554T01 in parts above about $150. Test yours first.
Loose screw clamp, split hose or cracked nipple on the cooler.plan to check all fittings and see if any are loose,
