B
B Ward
Guest
"I need to know the prop shaft
"I need to know the prop shaft runout specs on a 2000 Yamaha 225. A PDF or a link to the information would be great. I'm looking at buying a boat that I'm thinking has a bent shaft. It seems like I saw that .007 was the max.
Should you be able to "feel" a vibration with the shaft out of spec while running? The boat has a jackplate and hyd, steering?
What is the cause / effect of a shaft that is greater than .007? Leaking seals? Could this cause gear damage?
Any thoughts and suggestions welcome,
Thanks,"
Thanks,"
