2000 2hp model--2MSHY the pump housing will not fit over the D-shaft. there seems to be a two piece shaft and the seals in the upper pump housing won't allow it to fit over. and even if would slide over the shaft ,there is a larger square coupling at the d-shaft end that fits over the end of the crank. do you have to take apart the lower unit and pull out the d-shaft??? I hope not!! any help would be apreciated thanks.
