2000 15hp Mercury 2stroke tiller pull start went swimming while running
D
dholton
Guest
" Have removed carb and plugs.
" Have removed carb and plugs. Removed all water from carb and cylinders.
No adjustments were changed on carb, no jets removed. I have reflected back on a previous discussion that may help.(Sunday Feb.02 2003).
I did not see a ball or small spring come out of this assembly.
Facts: The motor will run, but only one cylinder at a time.It does not matter which cylinder nor if I remove either plug.No,the motor will not idle.
I am only able to keep it running by throttling it up at a mid to high rpm range. "
