2000 150 Optimax sudden throttle/power loss
I was on the river running 3/4 to full thrttl when the throttle suddenly went to idle, it did not stall. I shut it off and started right up but no throttle, would engage forward but there is no throttle or acceleration.
fuel or oil pump fuse? (not checked yet) or could this be the throttle sensor?
I would also like to know of the location of the "screen" in the water coolant line. Apparently this can get clogged affecting the water pressure of the coolant thru the motor.
quote from another thread "The technician took a harder look and found a clogged screen under the cowl. It definitely seemed to solve the (water flow) problem"
Thanks for any advise, Mike
