Walter Parks
3rd try at posting a thread here cant seem to post it right Hope I aint repeating the post.
I have A 2000 Voyager Pontoon Boat. Brief history, it sat in the boat house on my property for the last 12 years unused. It was running when I parked it. This year I decided to resurrect the boat. I am A Youtube partner User Name Pwalpar so I have been making videos about resurrecting the boat. new trailer tires, gas tank removed and cleaned out, carbs cleaned, plugs replaced. Hooked up the water hose and couldn't get it to start until I sprayed some carb cleaner in the intake. I fired off and ran fine. Primer solenoid dont click when key pushed in. if the engine is warm it will fire right off but when cool need more carb sprayed into intake. Read on the Seloc manual about the primer solenoid. Turned red handle up and it starts but was leaking some gas at the handle due to a crack. Took the boat to the lake and ran it a couple hours. Idle was rough. It is a pain however to have to remove the cover to start the boat. I ordeded A kit and installed it along with a new handle. I am no expert with my cheap ohm meter but I think the primer solenoid tested good. Gas leak repaired now but still no power to the primer solenoid. Wiring diagram shows the purple wire going all the way to the key switch. its rained all week here so I have yet to try starting it up since the solenoid rebuild. Still no click when key push in. Beginning to get stumped with my limited mechanical ability. Any suggestions will be appreciated. My name is Walter
