Bought this in December. Motor ran at this time and the fuel was ran out at the time of purchase. Used for first time in late March. Would run at low speeds for short time and quit. No problems at high speed. Would have to choke to start again. Discovered that I did not have vent screw open on gas tank and thought that this had something to do with it. Did not use again until 2 weeks ago. Same issue even with vent cap screw openned.
Took carb off and cleaned with carb cleaner. No evidence of any gum or dirt. Went out and tried again. same issue when starting. Took carb off again and cleaned again. Same issue. Next ting I did was to set the low speed to base or all the way in and backed it out 1 1/2 turns (it was backed out 2 1/2 turns). Same issue at different settings.
When I had the carb off, the low speed needle looked good and the float setting was ok. After motor quits the primer bulb is hard. The only thing that is different from the time of purchase is the tank. Came with a 6 gallon, but I'm using a new 3 gallon tank and added a fuel filter in line before the primer bulb.
Am frustrated at this point and don't know what to look for next. Any suggestions as to what I can also look at will be appreciated.
Any suggestions?
Any suggestions?
