checked carbs as per boat mechanics info by holding hand over each carb individually it bogged each cyclinder like he said. also checked anti siphion valve its okay.while checking fuel pressure at carb header had a surge of fuel 6to8 inchs long then nothing.waited a while to recheck and while running at idle had a small stream about 2 to 3 inchs .anybody know how much pressure there should be at 2000 rpms. isuspect the vro has a weak fuel pump. is there any wat to check for other problems.idles okay put in gear and it dies.....
