2000 0X66 200HP hi pressure fuel spec
crazy T
Looking for the hi pressure fuel spec idle and 2000+ RPM suspect pump is on its way out just want to confirm, thank you in advance.
Thanks I am only getting 30 PSI and idle while in gear is ruff almost feels like its running retarded will not plane going to check where fly wheel is at with #1 at TDC
Timing checked out good O2 sensor had a lot of carbon build up I took it all apart and cleaned the housing that it screws into replaced O2 sensor still have the same problem no power RPm will not go over 1500. I checked TPS has 0 volts showing at idle and WOT I ordered a new one but want to make sure nothing else would stop voltage any help is greatly appreciated.
