200 outboard cranksno start
flightcraft
"My motor was a little hard to
"My motor was a little hard to start today, cranked longer than usual. After it started, it was fine for a while and while pulling a skier, it just shut off. Will crank but won't fire. Any suggestions? I did check the ball in the fuel line and it has pressure."
Chewed a piston or cylinder -
Chewed a piston or cylinder - check compression
Toasted an ignition component - check for spark at all cylinders
Blew a fuel pump or massive clog in the carbs/injectors - troubleshoot the fuel system starting at the tank pick-up all the way to the reeds
