1995 oceanpro 200 e200txeoc. Starts ok runs great out of no wake zone idles fine. go out about 10 miles shut off while fishing, move spots a few times runs great on the way back then after a 5-10 minute no wake zone idle I go to dock and stalls when I go to neutral. Starts right up and smokes like the first start of the day then as soon as fast idle is done it stalls. Def not the time to be stalling. Been doing this for over a year but so far I have:
rebuilt carbs, link and sync, replaced/bypassed fuel/vro pump, new coils new plugs, new stator and power pack also replaced the rectifier, and head gaskets. Only thing left is timing base And maybe the carb floats as I set them flush with the edge of the bowl. I’ve read some issues with fuel boiling causing vapor lock but carbs are in a cold sweat when I come back. Just looking for some advice on this issue.
Compression is 105 all cylinders (cold).
also changed the reeds for chris Carson reeds. Idles smoothie and runs great but still no luck after a long run.
