200 Mercury not run in three years
avcm12
"My 200 Was winterized 3 years
"My 200 Was winterized 3 years ago. Fogged carbs, cylinders, changed lower unit oil and disconnected the gas line and ran it dry. I am getting ready to start using it again and want to make sure I do it right. I plan to remove carbs and clean, squirt tcw III in cylinders and turn over by hand, change lower unit oil, water pump, thermostats, plugs, and replace the oil injection system with the Marine Solutions kit (HAVE HAD PREVIOUS FAILURE OF MAIN OIL GEAR, 2X). I will run double oil from a 6 gallon tank to test it out as I have to empty the main tank of old fuel. Am I missing anything?"
