Jerryjerry05
Outstanding Contributor
Pair of 200 yams.2005
Both run fairly good at high speeds.
Stbd. motor uses 3X the oil the other does.
I looked at the linkage on both motors, the port is ok.
The stbd. has a cracked, loose connector, not broken but loose.
How to adjust or check the oil systems?
Haven't done a compression test yet.
The port motor trolling speeds: it starts at 750-800 then increases to 1500 on it's own.
Sometimes it goes back down, most times no. ???
The owner bought used and doesn't know much about the history??
