72harley1000
"I have a 1980 200hp johnson t
"I have a 1980 200hp johnson that was overheating on the starboard bank. there was good water flow on the port bank, but a slow flow on the starboard side I removed the bottom unit and replaced the impeller, which was defective( all the blades were there, but it was hard and they were not the least bit flexible). The water tube got damaged on the reinstall, necesitating that I remove the powerhead to replace the water tube. I started to put it all back together, and before I put the power head back on, I attached a hose to the water tube to check for any leaks. I had good flow out the top, with no leaks that I could detect, but the water was only coming out the port side on the part that the powerhead mates to. I put the engine back together, and put it in the water to run it, and now it is still overheating, and I have no water flow to the starboard bank. I am stumped, and the admiral thinks I should just dump the engine over the side. I hate to give up on it, as the engine runs exceptionally well, except for this overheating.
I guess one of my questions is, should the water be coming up both sides of that plate? I think one of the hole is for a return, as it appears that it goes to a hole in the front of that plate that is open to the lower leg. I don't have any idea where the other chamber goes. I looked at a schematic at my dealers, but the illustration is of such poor quality that even he can't make out items.
Thanks for any help."
