"the motor is a 1991 200 hp jo
"the motor is a 1991 200 hp johnson. the carbs were recently rebuilt, new water pump and thermostats. the problem is the motor will run great for between 5 to 10 minuts then the motor starts to shut down like you have hit a rev limiter. if you try to speed back up you get to 2800 rpm and it does it again. now if you turn the motor off then back on it will run fine for another 5 to 1o minutes"
