ricksterpr
"First time poster here!
G
Got a 2006 211cc Everglades with a BF200 (as of now 47 hours).
I was not able to reach the WOT RPM range (5000 -6000), attaining only 36 mph @ 4600.
Lowered pitch from a 15X19X3 (the prop that came with the engine, Solas) to a 15X17X3 Solas.
Good results, was able to reach 5250 RPM wih 40 MPH (alone in the boat, half a tank, very calm seas).
Changed prop to a 14.25X17X3 Turbo Progressive with exactly the same results with the same testing conditions(althogh better accelleration and out of the hole shot). The second time I used the boat with this propeller,same testing cnditions, I was able to get 40MPH again, but 5,360 RPMs.
Manufacturer says maximun speed in this boat is 36 to 40m at 5800 RPMs with this engine. Mounting position #4 (from top to bottom, recommended positionby manufacturer), and the recommended prop should be 15X17X3.
So I'm thinking maybe the tach is misreading?
Also, honda-marine tested this engine with the 14.25 prop on a boat that weights 600 pounds more. Couriously enough, this prop size is the one used by the boat manufacturer for their perfomance test. The results - 39.5 @5500 RPMs.
So I figure that with a lighter boat, I should be doing somewhat better?
Also, I'm developing the O2 sensor problem on Idle (check engine light, 1 second horn, no problems when runing). Would a faulty O2 sensor cause lack of revs in WOT?
I look forard from hearing frm all you experts.
Sorry for the long post, but I wanted to give as much info as possible..."
G
