melliott56
How do I remove the vertical drive shaft from the lower unit? Lower unit is off but I am unable to remove drive shaft.
The lower driveshaft has a nut holding the pinion gear in place.--------------Propshaft carrier and reverse gear must be out to get at the nut.----------------Top of the page under outboard parts gets you the pictures.
