"Hellow Everyone,
Haven'
"Hellow Everyone,
Haven't been on for awhile, been working on the motor. Replaced waterpump, thermostats, plugs, added fresh gas with a mix of 100/1 because engine hasn't been run for several years. Had sprayed fogger in the cyl to make sure everything was lubed. Hooked up the water and started it. Lot's of smoke..finally cleared up..replaced soaked plugs...started it again..runs with missing...revs up well but then goes to slowing down and reving up...oh yea..carbs were rebuilt...right side cyl are hotter to the touch...about 40 degrees hotter than the left which are cool..I believe I need to check timing and linkage settting but it revs well. Going to go direct gas from test tank tomorrow to rule out bad fuel. Is there a adjustment for the auto oiler? Any ideas where to go from here? New water pump working fine. Any help would be greatly appreciated as always."
Haven'
"Hellow Everyone,
