idk what happened but i blew something somewhere and my motors midsection is full of water contaminated oil
i damaged the prop on rocks earier in the trip but was still running ok for a few hours afterwards as i worked my way around the lake. on the way back to the car it made a weird noise and bogged down to less than half power, i thought i had either blown piston rings on one cylinder or lost a big chunk of the damaged prop as it vibrated a bit as well. couldn't throttle down or put it in idle without stalling but could restart it with the throttle up.
i pulled the water pump out and impeller looks ok, as do the top gaskets(replaced last year) bottom gasket is a little worn as i didnt change that one and the o ring at the bottom is a bit rough but overall isnt that bad i dont think...
compression in both cylinders is at 125 psi(checked twice)
any help would be greatly appreciated
