20 hp johnson
jojo663
"anyone know where I can find
"anyone know where I can find out the weight of my 20R71S. I'm going to pull it so I can do hull main. and repaint an old hull, just wandering if I can handle it by myself or get help to lift I've been looking but have not found a link for that info yet"
I've got figures of around
I've got figures of around 46kg give or take a little depending on shaft length for 1984 models. Its unlikely to be vastly different.
Two man job IMHO
"Weighs 'nothing'. If
"Weighs 'nothing'. If a short shaft no problems handling alone, unless You need to carry it for some distance."
"My 1989 johnson longshaft wei
"My 1989 johnson longshaft weighs 115 pounds with recoil start,but getting any outboard over 100 pounds off the back of a boat is alot easier with help."
"You can not compare the wheig
"You can not compare the wheigh of 89 25/30 to the 71 20. The through prop exhaust models are around 84-89 Kg!! The 'old' 20 should be max 40Kg. if short shaft.
I used to carry the 'old' ones, use a trolley on the newer ones. I only weigh 65 Kg myself."
"not sure if its a short or lo
"not sure if its a short or long shaft but it looks like a long shaft it measures approx. 32 inches from the center of prop shaft to the base of the motor, i'm not sure about metric conversion but with you guys info it looks like its going to weight in about 175 pounds if a kg is 2.2 pounds, which means i'll be getting help to lift this motor and move it, its got it has a put start, but has been converted to remote electric. no way my old back can do it alone.
Thanks guys, I love this discussion forum, you can always get with someone somewhere to get the answers you need. I'm not sure yet if the hull is a fixer or junk, a guy gave me the boat,motor, and trailer last monday to get it out of his yard. the trailer just needs to be rewired (seems his dogs do not like wires, no problem there) and I can use it to haul my jon boat around. the motor looks as if it were just rebuilt by pro's not at home. so worst case I have a 20 hp motor a trolling motor and a trailer for free even if the hulls a wash, and i found a place near dallas/ft.worth that sells used hulls for anywhere from $150 to $400 depending on what kind your looking for and sometimes on craigslist you can find one someone wants to get rid of just come and get it.
SAFE BOATING AND GOOD FISHING
THANKS"
"Joe, I believe that your mode
"Joe, I believe that your model gives a rough breakdown.
20 - horsepower
R - Rope start
71 - year of mfg
S - short shaft
I have a weight listed for the manual start 20/25 horse models (1970-75) of 86 pounds (dry - so no prop) and 97 pounds for the electric start models."
"Thanks Graham, like I said i&
"Thanks Graham, like I said i'm not sure about metric conversion. still 100 lbs. give or take a few I think i'll get a little help to move it. my old back ain't what it once was..
It's great to be in touch with people who have answers, sure was different before the internet.."
"I remember as an apprentice m
"I remember as an apprentice marine mechanic lifting Johnson 40hp,s into the test tank with no probs and now i am down to 15hp,s and think they're heavy
"i am right w/u......the owner
"i am right w/u......the owner of the shop used to tell me,..not to do it that way,.but...i was 23,and knew it all..,slung,em in the tank,..one after another,........now,...my back,...realizes...he was right............"
"That's what i'm talki
"That's what i'm talking about, I would rather by fishing, than laying in bed with a hurting back, yeah when i was younger i would lift and tote whatever, whenever now i just look at something and think ( why don't i get a little help from a young back to do this )"
"Ok, time to stop dancing arou
"Ok, time to stop dancing around here
Face it, we are all getting "old" and we are breakin' down.
We can call it "wisdom" or whatever, but the bottom line is it just plain "hurts" now to show how "tough" we are
