iceknight66
Hi all, I currently have a 20hp 89mod Evinrude. Now the problems Is, I cant get above about 2000 under load, On the muffs Is fine, While In the water the motor Idles perfect, runs fine in gear, But once Its opened up it struggles and goes nowhere. Since this problem started, Ive checked compression. Had the carb done. Replaced the Stator/trigger assy. Now the bottom plug seems to be getting an oily substance on it. Spark jumps a half Inch.
Could It be a lower seal? Or something else? I dont think Its a coil related problem...
Anything else to look at? ALso the temp switch has a wire that runs Up to the stator trigger assy? Could It be that temp switch in the front of the head? whats the wire do?
Thanks.
Thanks.
