Ih all
I have a 1997 johnson 200hps ocean runner with oil pump still installed and working.to mix my fuel/,,oil.
Problem im seeing is pure 2 stroke oil running down the out side below the engine from just below the fiberglass case around engine down to lower unit.
It does it running then keeps leaking for a while after turning engine off.
I removed engine cowl/cover to look inside for leak but can not fine any.
Anyone have any ideas
Thanks you
Thanks you
