Beckoning
How to put the main motor and the kicker on the same gas tank using a "Y" connection with one line + primer bulb going to each motor? Both 4-stroke. Both DO NOT run at the same time. If the big motor isn't pulling for fuel and the kicker pulls, does that create a problem? Primer bulb on each line? Should I install an on-off valve on one or both lines, or unnecessary?
