tlacombe97
Motor starts first crank, idles 5-10 minutes then stalls and dumps oil. Motor starts up right away and does the same thing.
Any ideas?
Any ideas?
It stalls out and then oil ends up in the engine housing and empties out the drain hole at the bottom. No leaks prior to stallingWhat does dump oil mean?
Thanks, once I get the boat back from upholsterer I will check it out.Could be too much oil or could be oil diluted with gasoline.
Drain and refill with the correct amount of oil. Clean up the oil mess. Start the motor and observe it to see what happens.
