Newb here seeking wisdom.
Have a late 80's Mariner 100 HP on a 16' fiberglass open bow. Runs like snot for a few mins @4000+ RPMs with more power than I need. Then drops down to about 2000 - 2500 RPMs even with WOT like it is fuel starved. Am about 90% sure it is not fuel related. Seems like something electrical warms up and then does not work properly. Took it in to my local marine mechanic as I dont have the time, nor expertise to diagnose. They came back and told me the engine is basically about to blow up and dont bother with it. It starts up, idles fine (for a Merc of that vintage) has tonnes of power so I call BS on the dude. He has steered my wrong on my chainsaw in the past but that is another story.
Have the shop manual and the CDI manual. Will get it out back on the water to properly diagnose with the right DVA setup this weekend. My understanding of these engines is that 2 cyls fire on RPMs below 2000 and then once it hits 2000 RPMs, the high speed stator winding kicks in and starts sparking the other 2 cyls, also at which point the high speed circuit in those two carbs kicks in as well. No low speed circuit on the +2 carbs. Once I learned it was a 2+2 engine it made much more sense. Manuals say it is either the high speed stator or the switch box. Or both. Taking wagers on which one it is!
My question is what cylinders are the 2 vs the +2 on these engines? That meaning which ones kick in when 2000 RPMs are hit? Firing order is 1-3-2-4 with 1 & 2 being opposite and 3 & 4 being 90 degrees from 1 & 2.
Stay tuned.....
Stay tuned.....
