john stevens
I have owned this engine for 3 years and it runs fine other than this. At full throttle 5600rpm after about 10 minutes the overheat sensor comes on. If you run 5300 rpm, no issues. After some investigation I found someone had removed the thermostats. I installed a new set of OEM stats and the overheat sensor now comes on in 2 minutes at 3000 rpm , removed stats and back to original problem. Now I verified the pressure control valve is in good shape which it is. Next replaced impeller and found the wear plate previously installed has a much larger feed area than the kit I have. I installed the new kit with the smaller feed hole no thermostats and the problem is still there as listed above. I can see at some time the heads have been removed as well. Its a fresh water engine and I don,t see any corrosion or obstructions up the feed tube when the gear case is removed. Any ideas?
