1999 volvo penta 5.7L
FISHFELLA
I am not sure but my motor may be toast. Pulled off breather and creamy substance built up around the lip. Like oil,water and gas muck.
I wiped it all off and left the breather off and let it run for 10 minutes. I started seeing water beads on butterfly flap and the creamy muck was starting to be visible again. On/under the right intake manifold, I rubbed my hand across the bottom of it and oil was all over it along with oil accumulation in the motor mount where it had leaked out of the motor somewhere. I still cannot see evidence of water in the oil from the dipstick. Is it done for?
The last 2 times I have taken it out it surges, especially when engaging it in gear and putting a load on it. Its getting alot of gas to it because with the breather off, you can see it the gas. I was wondering if that is caused by a compression now.
