Hello,
I am in the process of removing the lower unit and the access to the pin in the connector is very limited with the shifter in the neutral position. Should the shifter be put in reverse or forward to allow better access? Also, in removal of the pin, is that just tapping with a punch?
One other question, when the lower end went out I was running about 4,800 rpm. It didn't lock the engine up or anything but it revved doer a second I put it in neutral immediately. What are the chances it created damage to the upper end. I assume when I get the unit out I can inspect the upper splines to see if there is any damage to those which would indicate potential issues. Any other checks I should make before I put another lower unit in?
Thanks,
Tim
Thanks,
Tim
