H
homefree
Guest
" Iam having a problem with se
" Iam having a problem with servere oil smoke when engine has sat for 5 days or more & first started. This engine has oil injection & the fuel pump sometimes seazes until I drain the fuel pump housing and pump fresh fuel into it with the primer bulb. I beleive the oil injection mixing valve is the cause. all adjustments check ok as per factory repair manuel. I have heard that this oil injection system can be removed & the fuel/oil mixed in the fuel tank. I would like to fix system properly if I can,but looking at it I wonder if this system has a history of short lived repairs.
Thanks for any information or recomendiation. "
