Hi I have a 99 mercury OptiMaxx 150 hp last time I took it out it went into guardian mode 4 beeps every 2 minutes/ water overheat light is on, I changed out the impeller and both thermostats Fuel water separator water temperature sensor on the starboard side the little sensor on the port side and I believe the air sensor in the front of the motor, light still comes on and beeps do too. Water psi is about 3 at idle and at least on muffs 16 at 2800 rpm, Any help getting this light to go away would be greatly appreciated
