the cursed one
I recently bought a 17' wrllcraft with a johnson 130 v4. Previous owner put a lot of work Into the boat but de idea to sell. He replaced the starter, starter Selenoid, wires,plugs, had carbs cleaned and gave up. I picked up with finding about 8 broken wires, bad ignition, 3 bad ground wires,new kill switch and drained 20gal of bad gas. Finally got the ignition to turn the engine over but have no spark to any of the plugs. All the wires are brand new and still no spark. Does the nuetral safety switch kill spark if it's bad? I think it os bc if I put it in gear it'll turn over and spin the problem but I was told the nuetral safety switch doesn't control spark. Was told it was probably something to do with the magneto or something in that area. I'm tired of guessing and really need a real professional opinion. No one in the Rochester NY area will work on this motor and I'm no boat engine expert. Hope someone can help me without a wild goose chase. Also I unplugged the stator plugs and tested thr pins for continuity all the pins except for one have continuity. Does that mean I need a stator
