Hi
I have a 1999 Johnson 4 Stroke that was made by Suzuki. (70 HP). I am trying to find the software and data cable for this year motor. Please help if you can. Much appreciated. This is where I am at with it so far.
Thanks, Wes
I bought a Landau Pontoon Boat with a 1999 70 HP Johnson 4 stroke From What I hear it was made by Suzuki) it will start and run rough idle but cuts out when it gets to 3200 RPM.
The Injectors have been replaced, Plugs are new but not the Wires there is a good strong spark 7/16th through inline tester, Fuel Pressure at the rail is 38 PSI and Stays up when running up to 3200 rpm. Also pumping the Bulb while running does not seem to help it run better.
When you turn the key on I can hear the electric Fuel Pump cycle for 3 seconds as the manual says it should. I really think the fuel pump is fine. We used a new portable tank so Its not the tank Anti Siphon Valve... Tried a Known working MAP off another Johnson and no change....
Is there anyway to hook this motor up to a PC to get Codes? Also if so where do you hook it up and where to get the software???
Thanks for your help.
Wes
Thanks, Wes
Wes
