Hi everyone! I took my boat out recently and it ran well with the exception of running in idle. It has been cutting off within a minute of idling. Two weeks later it turned over with some strength but did not even try to fire up. I thought I flooded it. Tried to check for spark at the landing and didn't get any, but it was bright out so I thought I might not be seeing it. I tried it with my hand holding the screw driver and nothing. I picked up a spark tester, still nothing. So no spark. I tried removing the black and yellow wire from the powerpack. It still did not spark. It is my understanding that if the ignition switch or kill switch was bad, this would then create spark. The power pack was replaced last year. I think I have narrowed it down to powerpack, coils, or a bad ground? But I really don't know. I'm out of ideas. I have a multimeter and basic tools. Can anyone recommend a next step or things to test? I'm not familiar with the settings on the multimeter. But I can take direction well. Any help is appreciated.
Also, the oil has been deleted (if that makes a difference)
Thank you!
Thank you!
