I just mounted an old DF70, 1999 ( in Evinrude colors) to my 5,1m center console. It starts and idles like new (as far as I can tell). Acceleration is good and it runs smooth until it hits 3500-3700 rpm where it begins to stumble/surge, there is still a lot of travel on the throttle at this point. If push the throttle further (to full) it stops the surging and smooths out but never goes beyond 4200 RPM. The throttle valve clearly opens as the intake noise increases but the rpm does not. No codes or beeps. I had a code 4-2 yesterday saying CKP was faulty but I measured all three sensors today and they all check out. 207, 208 and 210 ohm. No error code today after fiddling with the connector so it may have been some corrosion or oxide.
Also tested the neutral switch since the stumbling begins at 3500 rpm. Works OK, closed in neutral and open in gear. Starter will not engage in gear, as it should be.
It occasionally needs some throttle to start second time shortly after a cold start.
The motor lives in the Baltic sea so it has survived corrosion OK. Previous owner replaced the ECU since the old one was not operational.
New spark plugs and new low pressure fuel filter. I am leaning towards a fuel issue/restriction. High pressure fuel filter or maybe the fuel pump screen. I do not have any equipment to check fuel pressure unfortunately. Could an air leak in the fuel line from tank to engine cause this? We tested pumping the primer bulb during surging but no change.
The Evinrude manual also mentions the MAP sensor hose as a possible cause of low power, however symptoms also include rough idle and that is something I do not see.
As I pull back on the throttle it smooths out at around 3500 rpm and cruises along like nothing ever happened. I do not really need to go faster but for water skiing etc I will need more power. Not to add that the boat is impossible to sell in this condition (at least at a decent price).
Thanks in advance for any help on where to look next!
