"Hey ya'll new to this,i&#
"Hey ya'll new to this,i'll get right to it.my Bf 90 sit for over a year.i did everything i thought I could being a non mechanic new plugs,new fuel,new oil.upon getting the engine started the warning buzzer begins going off as soon as engine begins to gain rpm which in return begins to starve.After talking with some knowledgable folks i ran a couple of cans of sea foam staight from can to try and clean up any varnish in carbs,it did seem to run better,but the warning buzzer still going off.I finally took the engine to the local honda guy who said,before i could get two words out,CARB JOB needed.After diagnoisn the engine he also said i had a problem with wire harness somewhere between engine and key switch.he quoted me more than I could afford.I took boat home and took on the job myself.Cleaned carbs,checked sensors,I have continuity in wire harness up to the key switch area,buzzer works,key switch seems to work(i can start it)The lamp indicator does not seem to work no lights.Could the lamp indicator cause the engine to protect itself and bog down.I was hoping that sense i have gone this far i could get out of this as cheap as possible.....sry this sounds like ramblin,I appreciate any feedback thanks....."
