M
mark jk
Guest
"I have 1999 90hp honda,when r
"I have 1999 90hp honda,when running wot about 5 minutes red alarm comes onengine shuts down to idle i canget right back on wot in secounds but in about same time will shut down.can back off throtle will run all day fine.I changed impeller thermostat cleaned on bottom side where water line goes in a pressure regulated spring thats what it looked to me,was told to take thermostat out leave thermostat cover off and run in tub of water at high rpm for a little bit to clean out any build up in ports.After putting back together pea stream still seems to not be as strong as once was and seems to fluctuate, any advice on what might be going on would be great."
