Hi guys
I am tearing my hair out with this issue as I cant seem to get to the bottom of it. Any help would really be greatly appreciated.
I have been experiencing high charging voltages whilst running the engine. The voltage starts off at around 14.4v but after 5-10 mins starts to creep up slowly until my volts gauge indicate 16.6v and starts flashing.
This is a true voltage as Ive measured the voltage with a multimeter across the battery terminals whilst running. My Garmin sat nav also confirms the voltage and my Icom radio has burnt out!
So far I have replaced the regulator/rectifier (no change), replaced the battery cable clamps ( not using wing nuts), replaced the battery switch ( was old and not making a good contact causing slow starting) and replaced one section of positive battery cable ( battery terminal to switch) and all of this has had no effect! Ive checked the engine earths etc and changed 2 batteries both brand new. One is maint free and the other is an Optima AGM. Yet still the volts keep creeping up.
Ive rigged up 2 brand new short test battery cables and wired them direct to the engine to count out anything forward of the engine in the console. It started very well with the stater running fast but yet after 10 mins the volts were back up to 16.4 volts (measured across the batt terminals).
Ive made up new battery leads but the last test showed it had nothing to do with the existing leads.
I have trawled the net for months now and have seen this problem coming up now and again but nobody posted a fix. I came across some saying that maint free batteries cause high charging voltages and should use a flooded cell old type battery but my maint free battery is a flooded cell type just non fillable so I cant see the reason behind this advice.
Some guys on other forums recommend you guys for help so many thanks for any advice you can throw my way
Mark
Mark
