Bought the engine last fall and it ran like a banshee. Earlier this year had it out and it ran fine. Had a fuel feed problem due to a collapsed bulb and replaced the bulb, fuel water separator and a major part of the fuel lines-all fittings ck'd for air/fuel leaks . Engine runs well at lower speeds until you put the throttle to it and it will wind up for a short while then bog down and regain RPM for a short while. Will continue to do it while losing power until I back off on the throttle and reduce engine speed. Then everything is fine at lower RPM. I'm thinking clogged high speed jets in the carb and wondering if I am ready for a carb cleaning or rebuild. A rebuild seems the way to go if the the carbs are the problems as the rebuild kits are very cheap. Engine compression is 140-143PSI. Thoughts out there from some of you experts?
