LakeBoaterNC
Hello. I bought the motor did the carbs., put on a new water pump assy,(BRP). Motor runs good. Good flow out of tell tail, but not as hard as my last 94 225, pressure is just under 5psi at 2000rpm on the hose. Motor has a temp. gauge, never went above 130 and heads felt even.... It is a long shaft, was i supposed to glue on the extension? I watched carefully to ensure the water tube went into the grommet.. Thanks for any input.
