This motor was made in 1999 and I have a Cylmer manual for it and was going to do some component checks and was to take some volt readings at pins from the main connector to the ECM but no where can I find a diagram of this big connector.
Does anyone have this or know where it can be found.
The motor fails to fire up, but cranks fine. There's 120 Lbs compression on all 6 cyls., also good spark jump at all 6 plugs.
The plugs came out looking pretty wet so I threw in a new set, still won't fire up.
I'm thinking there's a problem in the fuel delivery. The last time I had it out it ran decent but put out a lot of blue smoke and shut off when I went to idle.
Any suggestions are welcome along with where to get a diagram of the connector.
Dan
Dan
