1999 150 hp johnson ocean pro
peteg
"I noticed that when i start i
"I noticed that when i start it up i have a lot of blue smoke, it is hard starting, when i run it for a while the smoke goes away, someone told me that my vro pump might be bad or starting to that the membrain get a hole in it and pumps out extra oil, other wize the motor runs well, good rpm, no misses while running, a little rough in idle, any help please"
"there are oil consumption tes
"there are oil consumption tests that a shop can do,to verify operation of your VRO/OMS system...make sure your oil tank is not pressurizing."
"jwb, thanks for the reply, is
"jwb, thanks for the reply, is there anything else I can check for, To bad you are in Texas with 30 years on j&E, We could use someone like you in this area"
"yep,thanks,..but,..i'm st
"yep,thanks,..but,..i'm staying.. make sure....ALLof your fuel line conn are tight,air in fuel line w/cause excess oil..as well as dirty fuel filters..."
