I am troubleshooting an issue with my 1998 Yamaha C60tlrw. Starts up every time runs fine in idle and at low RPMs. Im experiencing intermittent power surges when at WOT and higher RPMs. The motor never stalls out completely just seems to be affected under load. Sometimes I can run the boat for hours without experiencing an issue but it is starting to happen with more frequency. i am by no means an expert mechanic but i started with the fuels system. I have cleaned carbs, replaced fuel pump and filter. I have run the engine off an external tank and experienced the same issue so i don't believe the issue is in the fuel tank or the fuel lines. Fuel lines delivering to the carbs appear to be fine with no leaks. Also, since first experiencing the issue i have noticed the my spark plugs are fouling quickly, after probably less the 20 hours (wondering if this could be related). Any insight on where to look next would be greatly appreciated.
Alex
Alex
