Hi guys
Was out on the water this morning, everything started of fine. Went to my fishing spot 13km from launch with no issues to report, moved around a bit with no issues once again. Weather turned a wee bit and decided to call it a day and head in. Motor started fine. Opened up got on plane then lost power. Check the primer bulb and it felt soft. Gave it a few bumps, starts up start going again. Check if all fuel fitting are inserted properly, checked the vent etc. All was well. Tested at low speed, same story run for a few minutes then dies. Open tank cap to make sure its venting. Seems like I'm getting fuel. Anyways use auxiliary to get back. Start up at home to flush and seems ok maybe bit on the rough side. So figure haven't change plugs, so put some new ones in just incase I had a dead plug (none looked bad). Not sure if the soft bulb is a new or not. Always goes hard when priming not sure if it stayed hard though. Anyways after changing plugs ran the motor for 10min up and down in revs and she didn't die. Check all fuel lines for holes and leaks with no clear culprit.
Any of you guys have any other suggestions what to look at. Just worried its a under load issue and it gets me again on the next fishing trip
