flatscrazy
My system has stopped transfering oil to the engine from the oil tank. I removed the tank, pulled the filter. I can blow air "backwards" through the filter, but not "forward". I assume the filter is failed/clogged. So on the bench I wired the pump to a battery and tested without the filter in line. I swear the pump is running backwards. I triple checked the polarity agains the manual. Positive, blue, negative brown. Ever heard of a failure mode where the motor runs backwards? I also double checked I had the pickup and discharge correct. Im stumped....
JJ
JJ
