Hi Guys,
I am trying to remove the driveshaft from the above motor. The gearcase and exhaust housing are split, I have removed the top bearing and retainer housing, which exposes the thrust bearing and plate, as well as the retaining screw on the outside of the gearcase. The driveshaft moves approximately 4 mm but no more. I have tried with the gearbox in neutral, forward and reverse, no difference. From the exploded views, I can see no reason why the shaft shouldn't just slip out. I want to overhaul the entire gearbox, there is about 3/4 turns of play in the gearbox.
Please help
John
Please help
John
