joshkeller
hey guys, first post. i recently was given a 35 hp 3 cylinder johnson. motor has great compression at 130 psi on all 3. rebuild the carburetors with new carb kits. new water pump. spark jumps 3/4" on spark tester. basically gone through the engine and replaced the recirculation lines, spark plugs, wires, etc. carbs were sync and lynced after rebuild. pulling plug wire from each cylinder each has the same effect. However the motor still won't open up. Verified it not being a fuel problem by spray gas and oil mix into the carbs and no change. Figured I had nothing to lose so I ran it on the water hose - still won't open up there either. Pumped primer bulb while running and made no difference. Here is in the water video and one on hose. Any ideas? possibly a slow mode because the oiling system isnt hooked up?
[video=youtube;EwIiE4rHyN8]http://www.youtube.com/watch?feature=player_embedded&v=EwIiE4rHyN8[/video]
