So I have a 98 Johnson 150 V6 Faststrike. I've rebuilt the carbs. The bowls were warped, replaced them twice now in less than two months. I've replaced the vapor separator cover & gasket (as it was warped and leaking). Now the motor uses way too much oil & smokes really bad. Repair shop wants $2200 to check manifold/throttle body gaskets, rebuild the carbs again & replace the fuel bracket. I also replaced the primer solenoid recently. The engine runs ok when first started, but when it comes up to running temp, starts to stall, run rough, and won't stay running. I can replace the aformentioned gaskets and fuel bracket for around $127.00. Repair shop said they put toothpicks in the air bleed holes, & the engine ran good. So they surmise an air leak. Any thoughts about where this air leak may be? Thought someone else may have had this issue before. Thanks Y'all. David
