Ok so ill try this question. I have a 1998 Johnson 70. I put new carbon reeds and new fuel lines from tank to motor, rebuilt the carbs(think i was to meticulous setting the float levels) i have a service manuel so went by specs. I put a new water pump in also. It starts right up and runs good, big improvement since the install of the carbon reeds. Im on the Peace river so you have to cruise just above idle because of the sandbars here. It stalls after a while and it wont start again. Seems like when i try to pump up the bulb its full of air. I have a 20 gal internal tank that i cleaned out good. This never happened before i put the reeds in. After bout an hour of paddling I tilted the motor up fully and started the key and it kicked over. Put it back in the water and ran fine again like it never happened. Even though I did all the work myself my experience is limited. I havnt performed the link and sink yet. Im taking her back out and just going to go up and down the river with the boat ramp in sight to see if it happens again. Any thoughts on what this problem could have been? What should be done next for my engine? It has 140 psi across the board. Full tank of non ethanol. Water separator installed with new filter. Ive only been behind the wheel of this boat for six months and on this river, if you break down you might be out there a very long time with just alligators to rely on a tow. Lol I may be missing something because of me missing experience. Could there have been air in my line? Could a carb float been stuck? Any feedback would be great? Thanks
