1998 four winns
jpal19388
"i have a 1998 four winns 5.7
"i have a 1998 four winns 5.7 gsi running rich,strong fuel smell at low rpm's,using alot of fuel.fuel pressure is 30 psi,replaced coolant temp sensor,map sensor.had injectors cleaned but think it is still bad injectors but can't find new ones.any tips please."
"Hi, I am a new user and a new
"Hi, I am a new user and a new boater.
I have a 96 four Winns.
The model of the engine is 432APHUB, can anyone tell me about the motor.
The outdrive is 386B413 and is marked SX
thanks"
"Go to this site
[url=""]h
"Go to this site
http://www.volvo.com/volvopenta/global/en-gb/marine_leisure_engines/engines/out_ of_production_engines/out_of_production_engines.htm
and in the "engine type" box type 432 and click "search". You will get two options: 432A and 432B. Because of the year, yours is probably the latter. Click on that box and you will get a description of the engine.
This link is to download the manual for the 432A, but I expect it will be virtually identical to yours or at least it should help.
http://vppneuapps.volvo.com/ww/PIE/ViewFileFrame.aspx?n=172216&r=2006-02-16-17-1 3-25&t=PDF&a=7746303&p=T403&d=OwnersPublication&s=15660459&lang=en-GB"
